Check Engine Light etc.....
Old Apr 1, 2007 | 04:56 PM
accord2000
Default Check Engine Light etc.....
I am a newbee to the forum. My accord check engine light came during a long drive. Error code says 1259... which is VTEC malfunction. I had a oil level low for a day or so. I changed the oil and filled it back to the correct line. Can I just reset the check engine light and see whether it comes back? Or should I take it to the dealer?[:@]
Second issue is when I use the remote and lock the door, the horn does not sound anymore. Also, the light does not blincks as before.... any ideas? Problem occured during recent cold snap.[][:'(]
Thrid issue is the rear driver window switch on the driver switch sub assembly is not functioning. I tried to open using the remote switch mounted on the rear door and the window works fine. Should I go for a new switch subassembly or should I further trouble shoot? [&:]
Thanks for your help.....
Accord2000
Honda Accord 2000 EXL
Old Apr 1, 2007 | 05:57 PM
Default RE: Check Engine Light etc.....
Hi new member...Please read the forum rules and Help topics, it's much easier that way for you to get your answers...also put all your info in your Profile for all to know about your vehicle..
Thank You !
WheelbrokerAng
Old Apr 1, 2007 | 08:46 PM
DTC P1259 corresponds to Obd1 code 22 which is a VTEC circuit malfunction. Unlikely that a brief period of low oil pressure would cause a circuit error. Reset the ECU and see if DTC returns. I think you'll have to get this done w/ an OBD2 device. Check w/ local auto parts store. Most will do this free of charge.
Cateastrophe
Feb 8, 2013 06:56 AM
45below
Dec 30, 2010 07:38 PM
afgsyko
Nov 8, 2006 01:44 PM
afgsyko
Nov 8, 2006 09:49 AM
