Check engine light solid code?
Old Aug 14, 2009 | 01:56 PM
Brandon Hollis
Default Check engine light solid code?
I'm having some transmission issues on my 92 accord lx automatic... I jumped the odb1 connector to get the codes and when i turn the key on the d4 light doesn't come on but the check engine light stays solid... is this a code? am I doing something wrong?
Also just in case anyone knows what the problem is, my tranny randomly downshifts to neutral and I have to restart the car to get it to engage again... already replaced the shift and lock sylonoids...
Old Aug 14, 2009 | 02:07 PM
91Accord_LX's Avatar
I had issues with my '91 and from the research I've done, if you can't pull a code your TCM is bad.
Old Aug 14, 2009 | 02:48 PM
If there's no error codes stored, the CEL is supposed to come on solid when you jumper the SCS connector & turn on the key.
Old Aug 14, 2009 | 02:49 PM
deserthonda's Avatar
you are not doing anything wrong,,,,,,,if there are no codes stored in the ecu,, when you jump the connector the lite will stay on solid.......normal ...
according to the symptoms that you are describing it sounds like an issue with the TCM ..
.BUT have it properly diagnosed by a shop ( specializing in hondas or Dealer ) before you replace it ..
Old Aug 14, 2009 | 04:07 PM
Brandon Hollis
I have had the TCM apart and didn't see the normal burnt parts, but it did have a sticker saying it was rebuild in 03... could it still be the problem?
techie768
Dec 9, 2014 05:35 PM
CyborgGT
Apr 25, 2012 08:31 PM
palmer
Sep 19, 2011 09:43 PM
aerodeckbassie
Feb 20, 2010 10:36 AM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
