Check engine light still on after MX
Old Aug 29, 2017 | 05:10 PM
bomberbill74's Avatar
Question Check engine light still on after MX
2000 Honda Accord 4cyl -- Checked codes at auto parts store. It translated to bad catalytic converter, O2 sensors, and suspect engine timing. Repaired/replaced the Catalytic converter, O2 sensors (upstream and downstream). Still shows the timing is off but engine runs fine. Seem to remember several years ago replacing a sensor for the engine timing. Don't remember where it is located. Does anyone have any ideas/recommendations.
Old Aug 29, 2017 | 06:25 PM
What is the actual code(s) that are left?
Old Aug 30, 2017 | 10:15 PM
Default code still shows catalytic converter
Could it be that the code remains and the cause is that I didn't cancel the codes after the repairs were made? How would you cancel the codes?
Old Aug 31, 2017 | 07:31 AM
Up through 2002-model, you can clear the codes by disconnecting the battery or pulling a fuse. In your case, fuse-13 in the end of the dashboard near the right-side door hinges.
If your repairs didn't fix the real problem, the CEL will come back on. OTOH, if you fix the problem, the CEL will eventually go out but error codes can remain stored.
What's the actual code number(s)?
Old Sep 1, 2017 | 11:01 AM
Default Fixd
I reset the code and both lights(check engine and maint ) remain out. The only code remaining after the repair was the catalytic converter. There's no way for the on-board computer to recognize that replacement. Had the car emissions checked and all is working well. Thanks for you recommendations.
Old Sep 5, 2017 | 08:59 AM
What's the actual code number?
proton8d
Sep 9, 2013 06:05 PM
brandon0409
Sep 8, 2013 11:05 AM
understand1
Aug 28, 2012 05:42 PM
HondagalGA
Apr 17, 2012 08:13 PM
Hondalover
Feb 26, 2011 09:02 AM
