Check engine light: undocumented code
Old Jun 21, 2005 | 11:18 AM
emaxxman's Avatar
Default Check engine light: undocumented code
My check engine light just came on. My mechanic checked it out and said the computer was giving him (according to the manual) "undocumented code". The car could be running fine, then it'll stall. I had the light on for about 2 weeks now and the car has stalled 5 times. It can be during an idle at a light after running for a half hour, it can be right at start up. After a stall/restart, it runs just fine.
My mechanic said it could be an oxygen sensor but until the computer gives him a real code, it's just guesswork that may or may not solve the problem but cost me money. I appreciate his honesty and willingness to make sure he pinpoints the problem exactly. However, I'm supposed to go on vacation soon with about 8 hours of driving roundtrip. I don't want to get snagged on my vacation with this problem.
Any ideas?
One more thing: it's a 98 Accord EX 4 door - 4 cylinder
Old Jun 21, 2005 | 08:31 PM
Evlampius's Avatar
Default RE: Check engine light: undocumented code
I have an idea for your vacation - how about a rental car? [&:]
That is very honorable of your mechanic not to lie to you but - please ask the exact code - note that some old scanners will not have the up to date information while we have our database updated every 3 months - so get to Autozone or your mechanic and read the exact Code # and please post it here, untill then - you're on your own
Old Jun 22, 2005 | 03:08 AM
I agree with Evlampius about going to AutoZone and getting them to run a OB II scanner at no cost to you.
My educated guess is a Idle Air control valve and map sensor, Hope I'm correct, if so let me know..
WheelbrokerAng
Old Jun 23, 2005 | 05:18 PM
emaxxman's Avatar
Well, the car stalled 3 more times and I had my mech check it out again. This time he got a more specific code...he didn't write the actual code number down though. He said it first gave him, "heater on oxygen sensor 2". He replaced the sensor and then the computer came up with "heater on oxygen sensor 1". He replaced both and was still getting the same code.
At this point, he thinks its the computer failing. He said there isn't much more he can do since it would start to cost him money that he couldn't justify charging me (because he didn't fix anything).
Mott
Mar 15, 2016 11:25 AM
Rockwell
Dec 26, 2014 05:07 PM
ddold@gkschools.org
Jan 29, 2008 03:35 PM
Joslinm
Dec 7, 2007 08:30 PM
