Check engine lights #72 &74
Old Apr 13, 2007 | 08:22 PM
caveman
Default RE: Check engine lights #72 &74
ORIGINAL: PAhonda
ORIGINAL: caveman
I didnt think about the using the vaccum to clean out the holes. But thank you for all the advice!...Yes I replaced the upper seals with the open end towards the inside of the valve cover.
Somebody can correct me if I am wrong on this one, because the DX/LX valve cover is different from the EX.
Describing the direction to install the seals can be confusing, so I copied a pic below of those gaskets.
Shouldn't the side that is facing UP (the sealed end) in the pic be facing the inside of the valve cover?
[IMG]local://upfiles/5767/7A96D8701262489BACD6ADC1CA878D8B.jpg[/IMG]
I can't see that pic really well, but I guess its cuz im blind....lol, but the side that is flat on the gasket with the little indentations on the inside diameter, should NOT be facing into the valve cover.....
Ok, now the new spark plugs and spark plug wires just came in today, I install those and the car started up really nice compared to last nites fiasco. But the idle is a little too low and the acceleration is a little hesitant.....is that my timing now?
Old Apr 13, 2007 | 09:14 PM
The pic is small, but the drawing in the shop manual is terrible.
I attached it below.
I remember reading that someone had installed the seals upsidedown, and that created the oil leak you described.
Your seals are different than my EX, so I wasn't sure how they go in there.
[IMG]local://upfiles/5767/B9CFE52591A54FF9BEEDDF4D41D6BFD2.gif[/IMG]
Old Apr 13, 2007 | 09:26 PM
caveman
ORIGINAL: PAhonda
I dunno but the seals look the same to pic from the first pic you posted.
Old Apr 14, 2007 | 03:25 PM
dmiscae
I have an Accord 2004 with 33K miles. I have the malfunction light come in twice. the first time the Honda dealer replace the gas cap and this did the trick.Second time I went right ahead and replace the cap myslef, but the lights is still here...any sugestions?
Old Apr 14, 2007 | 03:28 PM
deserthonda's Avatar
do not waste any money replacing unneeded parts.it could be a # of different reason why the lite comes on .....need to diagnose .. but car is still under warranty, take it to dealer, they should fix it free of charge
csh217
Apr 30, 2013 09:03 PM
rseattle1
Jun 26, 2010 04:10 PM
calspud
Oct 28, 2007 12:59 PM
accordEX98
Aug 20, 2007 03:43 PM
accordEX98
Aug 15, 2007 12:51 PM
