Check engine lite code 69
Old Feb 10, 2012 | 07:56 AM
biggamejojo's Avatar
Default Check engine lite code 69
I have a 1993 Honda Accord and when I jump the wires on the passenger side. My check engine lite blinks 6 times stops then blinks 9 times. Can someone tell me what the code is. Thnx
Old Feb 10, 2012 | 08:22 AM
Or it could be 2 different codes. It blinks 6 times then stops and blinks 9 times
Old Feb 10, 2012 | 12:18 PM
The blinks are all the same length? Or long vs. short blinks?
Code 6 = ECT (engine coolant temperature) sensor
Code 9 = CYP (cylinder position) sensor
There is no code 60 (6 long blinks)
There is no code 90 (9 long blinks)
ECT sensor is somewhere below the distributor with a 2-wire plug. Look for dirty/loose/corroded contacts in the plug?
CYP sensor is inside the distributor. Check out the wiring harness plug at the distributor.
biggamejojo
Apr 17, 2011 09:11 AM
MMWANG
Sep 7, 2007 06:21 PM
ew4558
Mar 23, 2007 03:19 PM
deserthonda
Jun 20, 2006 05:21 AM
deserthonda
May 18, 2006 05:24 AM
