Check engine lite code 69
I have a 1993 Honda Accord and when I jump the wires on the passenger side. My check engine lite blinks 6 times stops then blinks 9 times. Can someone tell me what the code is. Thnx
The blinks are all the same length? Or long vs. short blinks?
Code 6 = ECT (engine coolant temperature) sensor
Code 9 = CYP (cylinder position) sensor
There is no code 60 (6 long blinks)
There is no code 90 (9 long blinks)
ECT sensor is somewhere below the distributor with a 2-wire plug. Look for dirty/loose/corroded contacts in the plug?
CYP sensor is inside the distributor. Check out the wiring harness plug at the distributor.
