Check Engine Malfunction Indicator lamp on
Old Dec 19, 2007 | 06:37 PM
tce23233
Default Check Engine Malfunction Indicator lamp on
99 Accord EX 6 Cyn 55K miles. Wife's car and the light that says "check" and shows a picture of the engine came on yesterday. Says not running any differently. Checked the gas cap and oil level (2 qts. low yikes!) based on some search results. Should I reset the light and see if it comes on again or take to auto zone for diagnosis?
Thanks!
Old Dec 19, 2007 | 07:07 PM
Default RE: Check Engine Malfunction Indicator lamp on
Take it to Autozone and post the code(s) on here. There are a lot of possible faults that can trigger the check engine light on your car. The codes are read as P####.
Old Dec 19, 2007 | 07:09 PM
hondadude's Avatar
Sure if you can get the code for free, go for it.
lots of things besides the gas cap can set codes.
if you can post up the code we can give you some good info.
Just remember they read the code for free with the hopes of selling you something that you may or may not need.
Old Dec 19, 2007 | 08:30 PM
tce23233
Thanks PA and Dude. Is it OK to drive around for a few days or would that depend on the code I receive?
Old Dec 19, 2007 | 11:52 PM
That depends on the code, but since it runs normally, that's a good sign.
Old Dec 22, 2007 | 07:42 AM
tce23233
Received P0401 Code from Auto Zone. Probably a failed EGR Valve. They were selling them for $135 and said it was easy to install. They also said I might need EGR pressure sensor which they don't sell.
The showed me where the valve was and it looked like there were just two bolts to remove to replace. Should I do this myself? What about the pressure value?
Thanks
Old Dec 22, 2007 | 08:47 AM
BlkCurrantKord's Avatar
The EGR ports might just be plugged or gummed up from carbon. Get a Haynes manual and try cleaning the ports out and resetting the code before buying the valve. Its the easiest and cheapest way before you have to start replacing parts.
Old Dec 22, 2007 | 09:08 AM
tce23233
As long as there are no symptoms is it safe to wait a few weeks? Is there any chance that without notice the wife will get stranded?
Old Dec 22, 2007 | 11:26 AM
sir_nasty's Avatar
doubtfull that it would just up and quit on you but your fuel mileage might go down quite a bit
choochoo
Oct 13, 2008 03:14 PM
Ron505
Jun 19, 2008 05:34 PM
pham9006
Mar 22, 2008 12:04 AM
blahblah
Mar 18, 2007 02:33 PM
djsinister
Mar 1, 2006 03:11 AM
