checked solenoids and disconnected battery now cranks won't start
Old Jul 11, 2011 | 05:52 AM
Suggest a new thread on transmission and add any symptoms of trans faults.
Old Jul 11, 2011 | 09:11 AM
hack's Avatar
For anybody reading this thread for solutions on a 1990 Accord:
I was wrong about the component I thought was the Main Relay. What I described above is the cooling fan relay I believe. I now know the main relay or MFR is gray and dark orange and kinda hidden still even after removing the cruise control module. I'll add a link to some pics later. I found them late last night on my home computer and don't have the link here at work.
Old Jul 11, 2011 | 06:32 PM
hack's Avatar
These links are probably here already somewhere but I'm trying to be helpful to the next guy.
Honda Accord Main Relay Location
ENG: MAIN RELAY REMOVAL AND REPAIR (pics) - CB7Tuner Forums
I got it out and inspected it. It looks OK to me but I don't really know what I'm looking for. Will try to post a pic and ask what others see.
Old Jul 11, 2011 | 06:39 PM
hack's Avatar
Can anybody tell me how bad this looks to the educated eye? This is my main Relay.
Attached Thumbnails checked solenoids and disconnected battery now cranks won't start-dscn2202.jpg
Old Jul 11, 2011 | 06:53 PM
The cracks are very fine and around each component leg. To see whether there is separation will require a powerful magnifying glass.
Suggest you just re-solder all of them, adding a bit of fresh solder to each joint.
Old Jul 11, 2011 | 07:48 PM
Search viIZ8k60awY on YouTube. It is a video on dealing with soldering the main relay. He shows the style of relay you have later in the video.
Old Jul 12, 2011 | 05:07 PM
  #17
hack's Avatar
If that's Dave the car guy I did see it. It's one of the reasons I thought I could handle it, and the main reason why I removed the relay itself instead of the whole box.
Assuming for a moment the main relay is OK, could a bad ECU cause it not to engage and turn on the fuel pump, or does that happen regardless of the ECU?
Old Jul 12, 2011 | 06:12 PM
  #18
I wouldn't jump to the ECU first. There could be a number of sources for no power to the fuel pump.
I would do the tests for voltage and grounds on the electrical connector for the main relay. In the Common DIY treads post on top of this forum, there is a shop manuals link where you can access a 91 shop manual. If one of the wires is missing voltage or ground, then you can troubleshoot that specific circuit.
bjr001
Oct 7, 2014 09:29 PM
Kyle Hopfensperger
Aug 30, 2013 08:45 PM
dawgfn78
Apr 23, 2012 03:10 PM
mfskarphedin
Jun 29, 2010 02:36 AM
elderfoster
May 25, 2009 02:44 AM
