Cigarette Lighter Access - 2001 Accord
Old May 4, 2015 | 03:23 PM
Desert Boomer's Avatar
Most helpful.
Thank You,
DB
Old May 5, 2015 | 12:28 PM
Default Plan B <g>
I was wondering if it might be easier installing a second, full time outlet, a little forward of the existing one.
This area- http://cl.ly/asbH/Fwd%20Panel.jpg
Yes, I’m now into radio removal, but I just saw a YouTube video, and the guy had the radio out in about 2 minutes! From there it should be a straight reach down to that panel, to install a second outlet, wired ‘full time’.
2 Questions:
1- Is there anything right behind that panel that would make this a bad idea ?
2- At what year, does Honda's "Anti Theft Radio Code" requirement begin?
Thanks again,
DB
Old May 8, 2015 | 06:42 PM
From what I can tell there isn't anything "right" behind there.
I know some of the 5th gens (94-97) had the "code". Pretty sure ? all of the 6th and up have the code of the radio is factory.
Old May 9, 2015 | 11:59 AM
If there’s nothing behind that panel, I think I’ll pull the radio and drop down to there for a second outlet. Should be able to tap into the (hot) lead for the hazard lights,along the way.
I was worried the radio had some internal batt that activated in the code if the radio lead itself was disconnected. But the svs manual (98-02) references the radio code for any procedural requiring the battery disconnect, and I’ve changed batts many times, without needing a code. So, thanks to the svs manual, I’m ok. (or not
Thanks again (and again
Old May 9, 2015 | 12:19 PM
I think I found the ref to 01 Honda anti theft radio codes.
Short Version- the 01 OWNERS manual states the codes are only for the EX models.
As mine is an LX, that explains why they are mentioned repeatedly in the SERVICE manual (it covers 98-02 and all models) but that my ride (LX) never needed them when reconnecting the batt.
Old May 10, 2015 | 05:45 AM
Yea, I get confused on radio codes.....as you stated some trim levels have them some don't....I guess the luck of the draw is that both 5th gen's I've had/have and the Pilot have radio's that require them
odabiri
Oct 27, 2011 09:06 AM
ramachan9
Jun 27, 2009 11:00 PM
BrianH1290
Apr 15, 2008 06:20 PM
yankeeryu
Aug 24, 2007 04:09 PM
latoilette
Jan 9, 2006 03:48 AM
