Clear Coat Refinish
Old Nov 18, 2011 | 07:05 PM
rah140's Avatar
Default Clear Coat Refinish
I have a 2012 Honda Accord EX-L 2 dr V6 with 2000 miles and I noticed the paint was chipping in the left rear quarter panel, which was caused by the tail light lens rubbing against the metal.
The dealership sent it out twice to the body shop and was unsuccessful. They are now taking the car to another body shop for them to repair the paint, and when I talked to the person at the body shop, they told me that they will blend the paint in the affected area and reapply the clear coat to the entire quarter panel, because clear coat cannot be blended.
Questions:
1) Will I be able to notice the difference between their clear coat and the factory clear coat?
2) How will they handle the clear coat transition into the door jams?
3) Will there be over spray in the door jam?
4) If the door jam is taped, will I be able to see a line where the new clear coat ends and where the factory clear coat starts?
I appreciate your help.
Old Nov 18, 2011 | 11:54 PM
I am assuming they will put new clear coat on the section they repair so the new paint is even with the original paint. They will probably sand the entire quarter panel with fine sandpaper to rough up the clear coat. Then they will spray clear coat on the entire panel, so it looks even.
You will have to inspect their work to see if looks good.
Old Nov 25, 2011 | 05:05 AM
rah140's Avatar
They repainted the quarter panel for a third time and now there are fingerprints underneath the clear coat which are only visible in direct sunlight.
rogersah
Feb 3, 2013 03:12 PM
Zer0Vtak
Feb 21, 2008 12:07 AM
sir_nasty
May 14, 2007 04:01 PM
maro
May 7, 2007 04:10 PM
YeuEmMaiMai
May 29, 2006 05:09 PM
