Clicking after axle replaced
Old Mar 17, 2010 | 07:37 PM
creeve4's Avatar
Unhappy Clicking after axle replaced
I replaced the half-axle on the passenger side of my 1999 accord today. I took it for a test drive and after about 1 mile I started hearing a clicking noise from the passenger side. The noise increases in frequency as I increase the speed of the vehicle. Braking has no affect on the noise. I am sure I tightened everything and that the axle is fully seated in the transmission. Any ideas?
Old Mar 17, 2010 | 08:47 PM
Does it change when you steer? Try driving slowly in an empty parking lot. Straight, then turn each way. Does the steering change the sound?
Was it a NEW shaft? What brand? Some brands can be unreliable, but unfortunately I don't know who's bad & who's good. Except for actual Honda being good...
Old Mar 17, 2010 | 11:10 PM
96FiveSpeed's Avatar
Do check the tie rod play.I had a similar noise and it turned out to be the inner tie rod worn out.They can be mistaken for a shaft noise.
Old Mar 18, 2010 | 02:06 AM
kris_loehr's Avatar
I would make sure the axle is still fully seated in the trans.
Old Mar 18, 2010 | 06:59 AM
Yeah, I've seen posts from someone who drove around for a couple weeks before his axle fell out of the trans.
Old Mar 18, 2010 | 11:32 AM
creeve4's Avatar
Thanks for all the replies.
Turns out it was just the outermost metal clip on the outer CV boot that was rubbing on the steering spindle (whoever crimped it left a large bulge). I filed the crimp bulge down and it's good to go!
Old Mar 18, 2010 | 11:35 AM
Watch that thing. Might have been better to hammer it down, instead of removing metal. If it breaks, you'll want to catch it before dirt gets inside the boot.
Old Mar 18, 2010 | 02:50 PM
creeve4's Avatar
I only filed off about 1/32". I'll watch it though.
Wasatch Rebel
May 10, 2012 06:58 AM
JP98
Feb 28, 2010 01:07 PM
razcob
Nov 28, 2007 04:51 PM
nixalot
Jan 25, 2007 02:02 PM
kpearson10
Aug 23, 2005 02:34 PM
