Clicking noise while running A/C and heat...
Old Jan 5, 2012 | 09:45 AM
Silv333's Avatar
Default Clicking noise while running A/C and heat...
I have a 98, EX 4 door, 5 speed. When I turn the air or heat on the "1" or "2" setting, there's an annoying clicking noise. When I turn it to "3" or "4", the noise lessens or perhaps the expected high wind noise covers it up.
Took the car to the dealer, they THINK it may be the fan/blower. So for $250, it MAY fix the problem.
Any ideas what it could be????
Old Jan 5, 2012 | 11:59 AM
Sometimes a leaf gets into the blower housing and makes noise as the blower blades hit the leaf. Blower removal is 3 screws (at least on 94-97 models, yours should be similar). You will need a flexible screwdriver extension to access one of the screws near the pax kick guard.
If they are replacing the blower (may not be necessary), the $250 price is not unreasonable. If they are not, it's a bit high.
Just checked autozone repair manual and it indicates evaporator must be removed to access the blower in 98 Accord. This is a big job and $250 won't cover it. Maybe someone else knows different?
Old Jan 5, 2012 | 07:39 PM
Silv333's Avatar
Just watched a video on YouTube about changing blower motor, all it takes is removing three 8mm screws. I'm going to nose around and see what I can do!!! Thanks for the advice!!!
Old Jan 5, 2012 | 11:37 PM
Talking
That sounds like a case of the Air Conditioning compressor kicking in and out. What do you think Texas Honda?
Attached Thumbnails Clicking noise while running A/C and heat...-headbang_pc.gif
Old Jan 6, 2012 | 07:44 AM
From the description and dealer diagnosis, I assumed the noise was inside the cabin. If that is not the case, then AC relay could be cycling.
Old Jan 6, 2012 | 01:50 PM
Silv333's Avatar
Yes, the noise was inside the cabin. It seemed to be coming from the vent itself.
Old Jan 6, 2012 | 01:59 PM
When a fan is old and carbon brushes almost worn out, they will begin clicking. It is not loud or objectionable, but can easily be heard.
ramsur
Apr 7, 2013 08:09 PM
skijour
Aug 15, 2012 08:31 PM
godblessyouall
May 3, 2011 10:41 PM
Cessna172
Nov 5, 2010 01:22 PM
knownth
Oct 11, 2006 07:03 PM
