Clicks once then nothing
Old Sep 8, 2011 | 11:49 AM
Stan22490's Avatar
Originally Posted by JimBlake
I don't see where you had the battery tested under load. Until you do that, you can't rule out a weak battery.
If you don't want to do that, just measure voltage across the battery posts WHILE someone tries to start the engine. How low does the voltage get?
Wouldn't the fact that all electronics work fine while the headlight don't dim and I tried jump starting while leaving it connected for a while to a running rig.
I'm not saying your idea is stupid just curious
Old Sep 8, 2011 | 12:00 PM
The original repair to the battery cable could have resulted in a high resistance connection limiting battery amperage to the starter. Usually best to replace entire cable.
You can measure voltage drop across cable (positive probe at battery and negative probe at starter). Drop should be under 0.3 volts.
Old Sep 8, 2011 | 12:19 PM
Stan22490's Avatar
I figured that could be a problem do you think I should play it safe and replace the fuse box power cable and starter cable?
Old Sep 8, 2011 | 02:11 PM
All electronics & headlights take a small amount of power compared to the starter motor.
Connecting jumper cables to a running rig kinda rules out a bad battery.
I'm a fan of measuring things not just throwing parts at it. But there's a price-point where it might make sense to replace stuff anyway. It might be a loose/corroded connection at the OTHER end of one or both battery cables. Or it might be a cable fraying & coming apart inside it's own insulation.
Old Sep 8, 2011 | 05:37 PM
bigpat's Avatar
Almost A Senior Member
Please read post #3...
Old Sep 8, 2011 | 08:06 PM
Yeah, in post #4 you say you hooked it up & tried. Somehow I missed that...
Old Sep 9, 2011 | 12:24 AM
  #17
Stan22490's Avatar
Got it figured out when I took out the starter and tested it. One of the three cables was corroded snipped it and reconnected Resolved problem
Thanks everyone
pappy52
Apr 30, 2013 07:12 PM
Slidesquad240
Dec 31, 2012 11:32 AM
djcrunkmix
Sep 12, 2009 07:24 PM
jcoleman_11
Aug 27, 2008 10:36 AM
deserthonda
Aug 31, 2007 09:53 AM
