94 accord did stock swap clicks when battery hook up
Old Dec 24, 2012 | 01:22 PM
Slidesquad240's Avatar
Default 94 accord did stock swap clicks when battery hook up
Just put a junkyard motor in my car hooked up battery and it made a click coming from firewall. Car turns over without stepping on clutch have no radio or clock. And when key is out of ignition the check engine light stays on?
Old Dec 24, 2012 | 01:32 PM
Description suggests faulty ignition switch assy. Easy DIY. Check DIY forum and youtube videos.
Old Dec 24, 2012 | 01:54 PM
It wouldn't be grounds ?
Old Dec 24, 2012 | 01:56 PM
It can't be ignition switch it turns over
Old Dec 24, 2012 | 01:57 PM
Grounds might cause some problems, but I don't see grounds causing Check Engine light to remain on w/ keyswitch Off.
Old Dec 24, 2012 | 02:34 PM
Yeah I don't get it seems weird
Old Dec 24, 2012 | 03:14 PM
May be a problem with the clutch safety switch (aka starter inhibitor clutch switch) or the wiring for the switch.
For the manual transmission, there are two clutch switches near the clutch pedal. The one located a little higher up is the starter inhibitor clutch switch, which prevents the car from starting if the clutch is not fully depressed. The one located lower where the stopper pad contacts, is if you have cruise control on and press the clutch pedal, the clutch switch will cancel the cruise control set speed.
Old Dec 24, 2012 | 03:30 PM
Ok. What would I be checking if it's getting power
Old Dec 24, 2012 | 03:31 PM
The switch or wiring may be shorted. Try unplugging the switch and see what happens.
Old Dec 24, 2012 | 06:12 PM
Ok I'll give that a shot tomorro
