Foggy/oxidized headlamps
Old Sep 8, 2011 | 12:18 PM
Josh's Accord's Avatar
Default Foggy/oxidized headlamps
I have an 01 Accord LX with severely oxidized headlamps. A year or so ago I used the TurtleWax product to restore them, and it has already gotten just as bad again.
Is there a better product that buffs the oxidation out or do I need new headlamps altogether?
Thanks in advance!!!
Old Sep 8, 2011 | 12:41 PM
Most headlight restoration products works to some degree; however, if you want it to stay clear you need to use a restoration product like the 3M restoration kit, which sands away a few layers of the weathered plastic and then periodically apply a plastic protectant. The 3M kit is also available at Walmart and auto parts stores.
amazon.com/3M-Headlight-Lens-Restoration-System/dp/B001AIZ5HY
Old Sep 8, 2011 | 02:16 PM
The "plastic lens" is probably several layers of different material. At some point you lose the outermost layer (pretty thin coating) & then it's a game of re-polishing it periodically until you get tired of doing that & buy new headlamps.
Old Sep 8, 2011 | 04:55 PM
WhiskeySlick's Avatar
The lenses on my 01 are in the early stages of oxidation. How did the TurtleWax stuff work initially?
Old Sep 8, 2011 | 05:41 PM
dgLX2k's Avatar
I just did this to my 2000 LX Accord with the 3M kit I bought at Autozone. Kit cost me about $25, came with two levels of dry sand paper to put on the sanding disk that also came with it. Also came with a very high grit wet sanding pad that also velcro attaches to the sanding disk. Finally, it comes with a buffing/polishing pad that velcros to the same disk and the polishing compound to use.
In my case, it took about 30-40 minutes total, that includes the time to put masking tape on all the painted surrounding surfaces. The headlights went from a foggy haze I could not see through to almost crystal clear.
I can not speak to the longevity of the repair, its only been maybe a month, but I see no sign of degredation just yet.
Old Sep 9, 2011 | 07:23 AM
Hey Whiskey
It did okay initially, but not as well as I would have liked. I guess that makes sense since it was only $9 or $10. I am going to try another product. The oxidation drives me crazy!
Old Sep 9, 2011 | 07:24 AM
I am going to try this---thanks to everyone for the great tips.
DigitalDharmaBum
Jan 20, 2015 12:33 PM
FoggyO
Mar 27, 2009 11:37 AM
bambooyou
Oct 28, 2008 12:08 PM
somerustspots
Oct 22, 2008 06:09 PM
Sparco_racingVTEC
Jan 23, 2007 01:48 AM
