Climate Control Air Mode Won't Switch - 03 EX V6
Old Dec 8, 2006 | 11:06 AM
scarlin
Default Climate Control Air Mode Won't Switch - 03 EX V6
Hi,
I have a 2003 EX V6 Accord and the Climate Control mode won't switch. Does anyone have the following TSB or know how to fix this? I tried replacing the Mode motor assembly to no avail. This happened after removing the radio and replacing it.
VISIBILITYEFROSTER/DEFOGGER SYSTEM:WINDSHIELD:HEATER CORE
TSB #105 -- MODE/AIR MIX PROBLEMS AFTER CONTROL PANEL REPLACED AND REMOVED. *SC (NHTSA ID #10014128, MAY 16 2004)
EQUIPMENT:OTHER:OWNERS/SERVICE/OTHER MANUAL
TSB #06012004 -- MODE/AIR MIX PROBLEMS AFTER CONTROL PANEL REPLACEMENT. *SC (NHTSA ID #10014218, JUNE 01 2004)
Thanks,
Sean
Old Dec 8, 2006 | 11:43 PM
hondadude's Avatar
Default RE: Climate Control Air Mode Won't Switch - 03 EX V6
I'll go hunt around on the Honda interactive network to see what I can find; BUT I really wish people would understand that STUPID GOVERNMENT People at NHTSA attach their own numbers to the TSBs, that do not match in any way the manufacturers TSB number. They also carry the STUPIDITY a step farther by making up their own Title name, again it will not in any way match up to the manufacturers TSB.
Old Dec 9, 2006 | 12:05 AM
deserthonda's Avatar
if it was working ok before and it happened after you removed and replaced the radio ,, i would go back and recheck your work,, you could have left something unplugged or a loose connection ??
Old Dec 9, 2006 | 05:07 PM
hondadude's Avatar
This might help you
[IMG]local://upfiles/5417/27C9930A927D455088332AEF9E6838A2.gif[/IMG]
jaybee74
Apr 22, 2014 02:58 PM
LANman
Dec 25, 2011 09:05 AM
Abhishek719
Nov 27, 2011 11:08 PM
greenbean
Sep 21, 2007 03:14 PM
ohccord
Dec 7, 2006 01:46 PM
