Climate control module has no lights or power.
Old Nov 29, 2024 | 08:03 PM
JamesC!'s Avatar
Originally Posted by PAhonda
I found the green 22 pin connector to give you a place to start. On the row away from the clip/tab there will be a blk/yel, then a blank, then a blk wire at the end. They are likely a thicker gauge wire. If you have a volt meter, you can check the blk/yel wire gets 12V when the key is in the II position. The blk wire should have zero resistance to ground and not open circuit or high resitance (say greater than 100 milli ohms)
okay I’ll try that tomorrow wen I get off wrk ! Thanks for the heads up. I’ll give you an update wen I try that.
Tryinglikehell2
Aug 17, 2019 05:24 PM
Aaron Kyle Green
Feb 5, 2018 05:18 PM
Jaydyn
Oct 13, 2016 12:10 PM
karter25
Jan 18, 2012 08:06 AM
