clock/ air circulation button wont turn off
Old Aug 10, 2012 | 04:31 PM
linh's Avatar
Default clock/ air circulation button wont turn off
I'm having an issue with a 2000 accord lx. The clock/air circulation button will turn on and off while the key is out of the ignition. Started to pull fuses and when I pulled the clock/back up fuse on the passenger side the air circulation button turns off. When I turn the car on without the 7.5 clock/back up fuse it will turn on but won't turn off at times until I turn the car off. I'm thinking I have some sort of short.
Is there a fuse for the climate control?
What else should I start checking?
Old Aug 10, 2012 | 05:22 PM
It may be a bad ignition switch assy allowing circuit to be hot w/ key in OFF position. Try wiggling the switch in OFF position and see if this has an affect. If yes, the ignition switch assy (electrical multi-pole switch) should be replaced.
The 7.5A fuse disables the full time power to the clock. Another fuse under the dash enables power to the display and is switched by the igntiion switch.
Suggest purchasing/downloading a Honda shop manual. Check Online Manuals links in DIY forum. Check ebay for a used manual.
jimmy3fingers
Oct 4, 2013 08:02 PM
beasley
Aug 14, 2011 09:19 AM
desfam5
Aug 23, 2010 03:33 PM
old88dog
Jun 13, 2007 10:58 PM
LandSpeeder
Apr 27, 2007 01:03 AM
