Clutch clutch clutch
Old Jul 18, 2006 | 05:50 PM
tamb
Default Clutch clutch clutch
Hey gang,
I have a 2000 Accord, 200,000km 5 speed VTEC.
I have recently changed the clutch, fly wheel was ok, but I find this clutch is wearing very quickly. I also have a sqeek or squak when i depress the clutch pedal. Are the two problems related? The squak has been there since before the clutch change. I would hate to have to tear my car apart again to change the clutch so I'm hoping there is another solution. Could it just be a bad clutch?
Tamb
Old Jul 18, 2006 | 11:17 PM
deserthonda's Avatar
Default RE: Clutch clutch clutch
does it squeak only when you push the pedal up and down ?? did you lube the fork oivot when you had the tranny off?
try something.. pull the rubber boot off where the clutch fork is at slave cylinder, have someone depress the clutch pedal back and forth, get a can of wd-40 and spray where the fork pivots ..
as for clutch wearing very quickly ,, do you ride the clutch?? ( keep the foot on it ) ?? was it a cheap clutch assembly ??
Old Jul 19, 2006 | 03:18 AM
lightshow's Avatar
does you clutch chatter or shudder when you engage it? if it does, then thats because you didnt have the flywheel resurfaced when you changed out the clutch.
Old Jul 19, 2006 | 11:16 AM
tamb
I will try the WD40, it only squeaks when i press and let out the clutch, usually when its closest to the floor. The Squeak isnt the pedal itself, but I can feel it in the pedal.
As for riding the clutch, no. I bought my car with 130,000km on it and I put the last 70,000 on the clutch before it went. The clutch assembly was not made by Honda, just OEM quality.
And no, there is no shudder when I let out the clutch.
My poor Honda
Old Jul 19, 2006 | 10:25 PM
mbo1985's Avatar
How fast is it wearing out? Can you smell burnt clutch? Or is it losing grip?
Old Jul 20, 2006 | 06:21 PM
tamb
I've had it on for about 6 weeks now. When I first put it on it grabbed when the pedal was 1/4 of the way off the floor, now its more like 3/4.
Old Jul 21, 2006 | 01:05 AM
mbo1985's Avatar
it *could* be the clutch just wearing in. If you really think there is a problem though, you're probably right.
vetski179
Feb 24, 2015 04:26 PM
clutchless
Mar 8, 2011 11:50 AM
JimBlake
May 18, 2009 09:38 PM
