Code # 1259
Old Jul 22, 2005 | 05:49 PM
Uncle T
Default Code # 1259
I have a 99 Accord 2.3 liter manual transmission.
In every gear the car will stutter and drop out of gear at 4000 rpm's. I borrowed a computer and it came up with code 1259, which says "VTEC malfunction".
There are 4 codes for "Vtec malfunction", how do I narrow it down a bit?
Thanks in advance
Uncle T
Old Jul 24, 2005 | 12:13 PM
Evlampius's Avatar
Default RE: Code # 1259
The code P1259 stands for "Problem in the VTEC Oil Pressure switch circuit or VTEC solenoid Valve circuit"
very unfortunate -
there is a standard procedure to test what has gone bad. This is a high level procedure and I'm not sure you will be available to perform it at home.
To make the story short : it could be open between the Solenoid to ECU, Valve to ECU or damaged ECU, but like i said - unless you're really good with electronic diagnostics in cars I wouldnt recommend to do it yourself.
Old Jul 29, 2005 | 12:20 PM
Uncle T
I appreciate the help. I cleaned my engine out the other day and the check engine light went out. Stupid car...[sm=headbang.gif]
Old Jul 31, 2005 | 04:04 PM
Evlampius's Avatar
it means that you have a loose connection somewhere at the ground possibly.
...expect the same problem to pop up in the future
Old Aug 1, 2005 | 11:33 AM
Uncle T
It did, I will probably be finding a mechanic shortly.
Old Aug 1, 2005 | 10:11 PM
Evlampius's Avatar
exactly
corporategohan
Feb 20, 2009 10:22 AM
Mysticalbeauty3
Oct 6, 2008 04:17 PM
Mysticalbeauty3
rtmd01
Jul 9, 2007 11:04 AM
kilawind
Jul 7, 2006 09:31 AM
