Code 9 TDC Sensor
Old Sep 19, 2012 | 03:59 PM
c234876's Avatar
Unhappy Code 9 TDC Sensor
I am hoping someone can help me here. Just replaced the distributor on my 91 Accord with an aftermarket one - had a good mechanic do it. Recently I am getting a code 9 error when pulling the code. Local Honda dealer told me I have to replace the whole distributor for 460 dollars because the TDC sensor is inside the distributor. Is that correct?
Thanks
Montana Tom
Old Sep 19, 2012 | 06:40 PM
It is if the sensor is the problem which is doubtful since you've replaced the distributor once.
More likely a defective ECU. Measure sensor resistance at the ECU/Harness connector and if resistances are good, then ECU is the fault.
Used ECU's are fairly easy to find. See current post on the forum about failed ECU.
Old Sep 20, 2012 | 09:27 AM
c234876's Avatar
Default Code 9 TDC Sensor
TexasHonda,
Thanks for the help. That's what I will do.
Montana Tom
pondrun
Nov 8, 2021 09:40 AM
WayneG0531
Sep 22, 2014 12:31 PM
hondac27
Apr 27, 2012 09:28 PM
Toyomoho
Feb 23, 2009 05:29 PM
drfrankencopter
Oct 28, 2007 08:36 PM
