Code P0420 - What fixed your issue?
Old Apr 29, 2013 | 04:26 PM
5.0stang's Avatar
Default Code P0420 - What fixed your issue?
So this is the typical "inefficient catalytic convertor" code that gets thrown. It is the last one I have to deal with on my 231k 3.0L Auto Accord.
Is it the downstream 02 sensor (rear) that usually causes this? Is it the actual CAT?
What fixed your issues?
Thanks.
Old Apr 29, 2013 | 06:30 PM
Upstream O2 sensor, exhaust system leak ahead of converter, or failed catalytic converter.
You can monitor the secondary O2 sensor w/ a OBD2 scanner w/ monitoring capability. If O2 sensor voltage varies form 0 to -0.9 continuously or near those figures then converter is likely faulty.
Check for exhaust system leaks, shake the converter vigorously listening for rattling sound. If it rattles the converter matrix has collapsed and new converter is necessary.
Old Apr 29, 2013 | 08:32 PM
5.0stang's Avatar
So it is the 02 sensor closest to the engine (upstream)? Also, I do notice occasionally a little miss when cruising, which makes me think it is 02 sensor related, not the cat.
Old Apr 29, 2013 | 09:08 PM
Roader's Avatar
I thought the downstream sensor was related to a P0420 but I'm not familiar with V6 Accords. On my ~225K mile four cylinder a new cat fixed it. They just get old.
A related TSB for your car:
tegger(dot)com/hondafaq/p0420/A03-073(dot)pdf
Old Apr 30, 2013 | 05:41 AM
Do the easy things first; check for exhaust leaks and shake converter.
I would also reset ECU and see if code code returns.
Old Apr 30, 2013 | 08:45 AM
Dr. Drivability's Avatar
secondary sensor is the post catalyst sensor. not the upstream one. the secondary sensor is the one specific to monitoring catalyst efficiency. if no other codes exist, chances are good the cat has used it's nine lives
Old Apr 30, 2013 | 08:47 AM
5.0stang's Avatar
*At work* - So can the catalytic convertor just unbolt? That would be an easy check and I'll check for leaks/rattles. If the secondary (downstream) 02 sensor is reading different levels, the leak should occur between the first and second 02 sensor right? It doesn't seem like it would matter after the last 02 sensor.
On a side note, I have went from ~10 codes to one final one.
Old Apr 30, 2013 | 09:00 AM
what year is the car? maybe add it to your signature.
Old Apr 30, 2013 | 01:15 PM
Roader's Avatar
...the leak should occur between the first and second 02 sensor right?
Right. But even a small leak can trigger a P0420.
I've read about different ways to differentiate between a bad cat and a bad secondary O2 sensor. Aside from using a 2-channel oscilloscope to chart both O2 sensors at the same time, I don't know of any practical way to do so. I guessed that with high mileage my cat was bad and I happened to guess right. Cat's, like primary O2 sensors, fall in the category of long-term maintenance items.
Fortunately with scrap companies paying $100 with free shipping for your old cat, and a new aftermarket cat going for <$200 (49 state), getting a new one isn't all that expensive.
Old Apr 30, 2013 | 06:19 PM
Walker has bolt-on replacments.
Exhaust leak can be ahead of forward O2 sensor causing P0420. Apparently, exhaust gas can provide a false reference to the O2 sensor and cause incorrect fuel mixture. Other theory is O2 gets into the exhaust when exhaust pressure is subambient during engine pulse. I don't know who to believe
byebye2u
Dec 16, 2012 07:53 AM
mamtsberg
Oct 1, 2012 08:53 AM
Samzebian
Sep 22, 2012 08:51 AM
mig25
May 24, 2007 03:50 PM
reddcode
Apr 25, 2007 10:10 PM
