Codes P0420 AND P0430
Old Feb 10, 2016 | 05:56 PM
BlackLX4's Avatar
Originally Posted by PAhonda
You really should verify the upstream air/fuel sensor is responding to the engine exhaust and see what kind of fuel trims you have.
I'd hate to suggest spending money on a new converter and not have it solve the problem.
PAhonda, I just checked the fuel trims and the short term trim was bouncing between -5 and -10, but it mostly stayed in the -5 to -6 range. Long term trim remained steady at -1.6. Both are lower than they should be according to the service manual - the short term trim considerably more so. Manual states 1.0 +- 0.2 for the 2.3L. How do I go about finding the cause?
If you are outside of the country of CA there are plenty of places you can find a replacement cat for decent prices (rock auto, local parts store with discount codes, ect). "IF" you go down that road, go ahead and get new O2's (up and down stream) and replace those as well, if they are more than ~a year old. Then look online for a "used cat buyer" - the metals used in them will get you some money back.....say $50 to $100.
I will definitely look into that!
Old Feb 18, 2016 | 11:22 AM
BlackLX4's Avatar
Bump. The fuel trim levels are telling me that the engine is running too rich. Should I look for a potentially bad fuel pressure regulator?
Old Feb 18, 2016 | 12:14 PM
The quick test for a ruptured FPR is to look for liquid fuel in the vacuum hose. There should not be any fuel getting into that hose. (But that doesn't rule out some more subtle problem with your FPR).
A proper test of the FPR is to measure fuel pressure while the engine is running.
Old Feb 18, 2016 | 12:55 PM
BlackLX4's Avatar
Don't you need a special gauge and adapter to test the fuel pressure, or can it be done with a regular fuel pressure tester?
Old Feb 18, 2016 | 04:00 PM
I don't think the gauge is special. Just the fittings to connect up to that funny arrangement of fittings on the firewall. That's where the fuel supply pipe comes up from the fuel pump & connects a rubber hose over to the FPR.
R.A.D.
May 4, 2014 11:23 PM
c_smith707070
Aug 26, 2012 11:19 AM
accordhybridowner
Oct 27, 2011 09:16 PM
capthoward
Jun 25, 2011 07:25 AM
PiksPal
Dec 31, 2010 10:03 AM
