Coil location
Old Apr 17, 2008 | 12:00 PM
pshepard8's Avatar
Default Coil location
So I've got this 93 LX with an F4 motor in it. I'm pretty sure they've put this motor in and that it's not factory. They've had some issues with it, and I picked it up pretty cheap. What I need is someone to tell (and or show with a good photo) where the coil is supposed to be mounted. It was just lying beside the distributor on the top of the motor. I think the bracket hooked to it is broken and I can't for the life of me figure out where it's supposed to be. Thanks in advance for the help!!
Old Apr 17, 2008 | 12:30 PM
finch13's Avatar
Default RE: Coil location
I don't have a pic, but it should be on a bracket behind the distributor and on the left side of the EGR valve.
Old Apr 17, 2008 | 09:18 PM
This might help a little. The coil bracket is #2,but it doesn't really show where the bracket is mounted. Seems to me it's on the back of the head, just below the valve cover split line??
Old Apr 17, 2008 | 10:14 PM
finch13's Avatar
The vertical bolt goes into the head and horizontal bolt goes into the coolant thinger...
Old Apr 17, 2008 | 10:17 PM
finch13's Avatar
Pics coming in a minute, pshepard8, I'm sending the bracket with as well.
Old Apr 17, 2008 | 10:24 PM
finch13's Avatar
Here's the general area:
Here's the zoomed in bolt locations:
Old Apr 18, 2008 | 04:47 AM
pshepard8's Avatar
Friggin sweet... thanks for the help fellas! Now, just one more new to honda question. You'll also be setteling a bet. Which plug is number 1? Is it the drivers side or the passenger's side? This is almost like learing to work on cars all over again!
Old Apr 18, 2008 | 06:44 AM
finch13's Avatar
I want to say drivers side... I think the firing order is 4-2-3-1, but someone correct me if I'm wrong.
Old Apr 18, 2008 | 09:19 AM
finch13's Avatar
Here it is, courtesy of about.com:
Old Apr 18, 2008 | 10:26 AM
pshepard8's Avatar
I had the answer right in front of me the whole time yesterday. I found that yesterday, and didn't realize it was the cylinder order on the right side of the picture. Now I do really feel like a noob.
phantomgrey92
Oct 9, 2013 04:45 PM
jhungalmunkee
May 8, 2012 03:15 PM
sir_nasty
Apr 16, 2006 05:56 PM
19accord95
Feb 11, 2006 02:06 AM
