Colorado Road Trip from Texas
Old Jun 22, 2015 | 11:30 AM
Viets90's Avatar
Default Colorado Road Trip from Texas
Hey guys I am in need of suggestions, advice, and tips please. I am planning to drive from Dallas, TX to Denver, CO. This will be a 13 hour drive there and back. I will be driving around the state a bit for some good adventure and hiking. The total trip was estimated to be about 2500 miles over the span of 4 nights. The drive there and back I will do 12 hours non stop except for gas (I did this last year).
What I would like to know is if you guys think my car can make it no problem? I am not super car tech, so I am worry about something happening in the middle of the road. Please let me know if I should drive non stop like that? If its bad for my car? What typically goes wrong in a lost distance drive?
My car condition: 174k miles. I do oil change every 3k miles. It has never broken down on me yet (bought the car at 100k miles) except for the transmission gave me a lot of problems until i got it rebuild. It seems to runs good and solid. I drive to my University 4 days a week 1 hours each way no problem for the past year.
-Tran rebuilt at 136k miles
- Cap and rotor at 136k miles
- New radiator at 137k miles
- Timing belt, tensioner, water-pump and 3 seals that typically come with that kit was done at 172k miles.
-exhaust gasket - 140k miles
- spark plugs at 136k miles
-Thermostat at 127k miles
Any advice and tips is gladly taken. Any suggestion on car maintenance prior to trip will be taken!
Old Jun 22, 2015 | 05:40 PM
Sounds like the car is well taken care of. I would just make sure to check for any low or leaking fluids, or unfamiliar noises leading up to the trip.
It is actually better for a car to stay running than it is to start and stop.
Old Jun 24, 2015 | 08:29 PM
UhOh's Avatar
I did the similar long distance thing with a 239,000 mile '92 Accord last month.
Worked fine; I'd just check rad coolant level and oil level each morning. Sounds fun.
Old Jun 24, 2015 | 08:33 PM
I don't see any info on brake pad condition. You will need good brakes and plenty of pad to manage mountains. Suggest an inspection of brake pads.
Old Jun 25, 2015 | 11:08 AM
As another member said above, just keep checking all fluid levels and your tire pressure every time you stop for a gas up, all should stay good that way.
Have a Safe and enjoyable trip.
ltl lifer
Jan 3, 2014 11:54 AM
shipo
Apr 24, 2013 05:19 PM
alexjs77
Aug 11, 2008 04:35 PM
mildar34
Apr 20, 2008 02:40 PM
Alien VFR
Feb 3, 2007 05:36 PM
