compressor and condenser replacement oil charge question
Old Aug 25, 2015 | 09:45 AM
jasonmcc's Avatar
Default compressor and condenser replacement oil charge question
First post to a great forum.
I am working on a 2003 Honda Accord EX 4 door sedan with a 2.4L DOHC engine. I am repairing the a/c.
It is my sons car and my daughter damaged the front end causing a leak in the condenser. I decided to replace the condenser + receiver drier and the compressor because of a non-serviceable clutch that is bad. Some where in the repair process the compressor got scrapped before I could measure the oil in it.
The replacement compressor was shipped with no oil but states to add 6 oz. of PAG. I don't trust that I won't be adding too much. I have always just measured for the compressor and added a little under an ounce for the condenser. I will not be flushing the system because the compressor did not fail internally just the clutch.
My question is - New compressor + New condenser + New receiver drier = How much PAG oil?
Old Aug 25, 2015 | 10:46 AM
I also struggled w/ same dilemma when overhauling my 94EX system. I pulled compresssor and drained to find virtually nothing. In the end I opted to add 7-8 oz. I checked various sources for "system capacity" and had conflicting advice. I added up all the individual capacitites and decided to add at least that amount. My reasoning was two fold: 1) I wanted to be sure to have adequate lubrication and 2) allowance for future loss (you lose lube everytime you check pressures).
My performance was and still is excellent over 10 yrs later. I did remove evap once to clear a clogged condensate drain, vacuumed, and recharged w/o adding lubricant.
My advice is to err on the high side, not low side. There is no absolutely correct amount w/o a complete flush of system. Total value of all individual oil amounts is 8-9 oz (from specifications sheet of shop manual).
Old Aug 25, 2015 | 02:34 PM
jasonmcc's Avatar
Thanks for the info. I think I will do 7 oz. in the compressor and a full oz. in the condenser. I haven't touched the evaporator so I won't add that to the equation. 9 oz. feels like I would be pushing it. Thanks again.
ak474u
May 4, 2015 11:15 PM
Dracco
Dec 27, 2010 07:41 PM
ramman05
May 11, 2009 07:58 AM
BlueByYou
Aug 2, 2007 07:29 PM
Accord98Retro
19
Jul 6, 2006 09:43 PM
