compressor not working
Old Jan 10, 2016 | 02:14 PM
Rilex's Avatar
Default compressor not working
compliment of the season to you all in HAF. My compressor has gone bad for sometime now so the AC is not cooling. My question is instead of replacing the compressor completely I was told it can serviced and repaired maybe last for a year or more. How is it possible to be repaired? Presently i don't have much money for a new compressor now hope to get one later. Honda Accord 1998, 4cylinders, 2.3L, auto transmission, Vtec engine. That is the only problem the car has. The accord drives great. Hope to hear from the forum soon. Thanks
Old Jan 10, 2016 | 03:49 PM
Dr. Drivability's Avatar
Who told you it was bad? The compressor won't run if the refrigerant is empty or low.
You can do a quick test of the clutch coil by removing the clutch relay in the underhood fuse box and jumpering terminals 1 and 2 together, engine OFF. If there is a click, the clutch coil and the wiring to the clutch are good.
here is the relay diagram:
Old Jan 10, 2016 | 07:17 PM
Who did the diagnostic work? Can you find out exactly was diagnosed as bad on the compressor?
Are you planning on doing the work yourself?
ak474u
May 4, 2015 11:15 PM
Alimaxor
Mar 18, 2013 04:22 PM
cactuar12
Jun 13, 2012 08:02 PM
BonnieO
Jun 3, 2008 02:16 AM
Pauls95
Apr 7, 2008 01:45 PM
