Condenser fan won't turn on after replacing
Old Jul 31, 2023 | 03:21 PM
spencer596's Avatar
Default Condenser fan won't turn on after replacing
So I have a 2006 Honda Accord v6 and I recently just replaced the fans because the motors were bad. For some reason the condenser fan won't turn on. Now I tried pretty much everything. Replacing fuses, switching relays, checking if the wires are providing power, replacing the thermostat, replacing coolant temperature sensor and using those jumper cables to turn on the condenser fan. I feel so stuck on this issue because I have no clue what the stupid issue is and I'm about to get new relays tomorrow, but I doubt it would fix the problem. Does anyone know how to fix this dumb issue? I looked everywhere on the internet about what the problem is and I tried everything to fix it so. Also I turn the ac on when running the car and both fans should turn on except only the radiator fan turns on and not both of them.
Old Aug 5, 2023 | 07:27 PM
I was out of town last week, so did you get this fixed?
You may want to start your testing at the fan electrical connector and use a test light. See if you are getting power to the + wire of the fan when you have the engine running and a/c turned on. Then supply power to the ground wire and see if you have a good ground. You can also test for power and grounds at the relay connector for the condenser fan.
F22Bard
Apr 22, 2014 03:25 PM
MichaelKline
Apr 29, 2012 12:52 PM
or12101989
Oct 5, 2009 10:06 AM
valerie
Sep 26, 2009 11:43 PM
1BADSS
Sep 12, 2006 05:18 AM
