Considering a Honda Accord but have concerns
Old Feb 16, 2010 | 11:50 AM
paullysc's Avatar
Default Considering a Honda Accord but have concerns
I maybe purchase a 2007 or newer Honda Accord. But have a couple of questions.
1. Are there issues with sunroof/moonroofs in Accords? I've always been of the thinking that they're just going to leak and are a waste. Curious to find out the truth.
2. I noticed the 2007 model doesn't have the audio aux input. What options are there? I don't mind paying for something that's well built to give me this. I have got to have some way to play the music on my iphone
thanks
paul
Old Feb 16, 2010 | 06:45 PM
RA1525's Avatar
1. Never heard of any problems with FACTORY INSTALLED sun roofs.
2. There is always a work around, you will have to figure that one on your own. Always a work around!!
Old Feb 16, 2010 | 06:47 PM
kris_loehr's Avatar
I have never had a problem with a factory Honda sunroof. Only you can decide if it is worth it. I like to have the option but don’t use it. Your other question I can’t answer but with most cars you can’t just get a universal radio anymore as a replacement.
Old Feb 17, 2010 | 07:27 AM
1 - I've never had a problem with a factory sunroof.
2 - Stereo places like www dot crutchfield dot com have iPod adapters you can install. That way it charges the iPod, and you don't have to remember to PAUSE the iPod when you turn off the car.
Old Feb 17, 2010 | 08:23 AM
Pop Pop's Avatar
No problems with a Factory Installed sunroof. Only issue for leaks would likely be a plugged drain from debris. Just keep the drains clean. I've a 2000 and has never had to be cleaned.
Old Feb 17, 2010 | 08:58 AM
00AccordLX5spd's Avatar
Registered User
The sunroof in my wife's 95 Accord NEVER leaked. We traded it in a year ago. Never had to clean any drain holes either.
I wouldn't think the iPod adapter should be too hard to install. Crutchfield normally gives out installation instructions that are pretty straightforward.
Old Feb 17, 2010 | 11:25 AM
Crutchfields instructions were good. But 2003 & 2007 are probably different for dismantling the dashboard.
Old Feb 18, 2010 | 04:29 PM
Registered User
^ yeah I wondered about the whole "dashboard dismantling" process. I used crutchfield's instructions about 10 or 11 years ago on a 90 Mustang (installing a head unit.) I did not have to disassemble the dash at all. But i know newer cars make it a lot more complicated to get the head unit out.
Old Feb 18, 2010 | 09:41 PM
I did it on a 2003 Accord & it helped to know how the tricks of which panels to snap off in what order. I also had a Helm book for that car, which was more detailed than the Crutchfield instructions. Still, I could have done it with only the Crutchfield sheet.
Then a few years later I wanted to move the unit to a 2007 Civic. Crutchfield emailed me the corresponding instructions, even tho I didn't buy a new adapter at that time. Strangely, that one was easier, even though larger portions of the dashboard needed to be opened up.
Old Feb 19, 2010 | 12:05 AM
mamtsberg's Avatar
Question #1 - 2001 Accord, never a problem with sunroof
Question #2 - can't answer, still using 8 track
dans169
May 2, 2012 02:22 PM
dans169
Apr 12, 2012 11:02 PM
rosie
Jul 27, 2011 05:03 PM
zdawg_42
Apr 5, 2009 11:35 AM
knadd
Mar 29, 2009 01:08 PM
