Coolant disapearing?
  #41
Old 06-02-2011, 04:03 PM
nickmg555's Avatar
Still no luck. vice grips on the heater core hose with the flow control valve on it and still have coolant loss. i can usually smell it near the end of a trip when the engine is rather hot. im running out of ideas about where this leak may be. it would seem to be a leak which must be evaporating when it hits the engine.
  #42
Old 06-02-2011, 06:12 PM
desertmike1's Avatar
In order to stop any fluid "pressure" from reaching the core, both hose's need to be pinched off.
  #43
Old 07-13-2011, 11:43 AM
nickmg555's Avatar
All signs point to the heater core. This thread can be marked solved. Thanks everyone fir the inputs.
  #44
Old 07-13-2011, 12:01 PM
bigpat's Avatar
Almost A Senior Member
Because of the nature of the removal/replacement of the heater core is a ton of work, I would just disconnect the hoses and bypass the core by sleeving them together ...Use good clamps !! I would also drain the oil and measure the volume to verify that it doesn't contain antifreeze. Over 4 1/2 qts, you have a blown headgasket.
fvansan
10-04-2013 06:27 PM
Haccord96W
10-16-2011 12:50 PM
dannyp1981
06-29-2009 05:08 PM
07-03-2005 03:39 AM
habeel
06-14-2005 10:16 PM
Quick Reply: Coolant disapearing?
