coolant flush
Old Feb 28, 2010 | 01:35 AM
honda97acc's Avatar
Default coolant flush
I did some searcing but could not find anything aout how to flush the coolant out. I have a 97 accord, 2.2 non v-tech, automatic. what is the best way to flush the coolant. i dont need a new pump or anything, just want to get some new fluid in there. thanks fot the help.
Old Feb 28, 2010 | 08:29 PM
One way is simple drain & fill.
Otherwise, I like to remove the T-stat & run lots of water through everything. Fill & drain a few times until the water comes out clear. Then fill & drain with distilled water.
Then put the T-stat back in, add full-strength antifreeze in 1/2 the capacity shown in the specs (probably just under 2 gallons so add just under 1 gallon). Then fill the remainder with distilled water to give it 50/50 mix.
toniboicb7
Feb 7, 2013 12:31 PM
jafriede
Jan 3, 2013 05:10 PM
riverman
Mar 27, 2010 07:41 PM
dtcaccord
Jun 4, 2008 09:54 PM
wayneboard2
Dec 8, 2006 11:56 PM
