Tie Rods and coolant flush
Old Mar 27, 2010 | 09:42 AM
riverman's Avatar
Default Tie Rods and coolant flush
Just had my 93 accord LX auto. In the shop for tires. While i was thier, they did a courtesy check. From what they say, My left-outer tie rod end is lose. Still learning on how to fix this great car up, I was wondering if there is anything i can do myself to fix this or repair it? And i need to do a coolant flush, is there any type of coolant that would be the best for my car. ( I drive like a bat out of hell)
Old Mar 27, 2010 | 01:37 PM
If the outer tie-rod is loose, then you will have to replace it.
With the correct tools, it is a pretty simple DIY job.
Old Mar 27, 2010 | 07:39 PM
96FiveSpeed's Avatar
Its very easy to replace the tie rods.Just make sure it is either the outer or inner.A shop told me my outer tie rod was loose,but when I got home and took the wheel off,the inner one was bad,not the outer.Honest mistake but I was able to diagnose it right away.
Old Mar 27, 2010 | 07:41 PM
Forgot to add,just use the factory specified coolant/mix.You can add a little more water to the mix for the summer months.
Or you can buy the premixed 50/50 already mixed bottles and use those.
They work for all types of coolants.
James Vodera
Aug 13, 2013 10:36 AM
luckyyyyy
May 12, 2011 12:35 AM
jerrym
Apr 9, 2010 12:05 AM
dtcaccord
Jun 4, 2008 09:54 PM
thunder_x
Oct 31, 2007 07:34 AM
