Coolant issue
Old May 16, 2016 | 02:25 PM
Damonj's Avatar
Default Coolant issue
I pulled in my driveway and all the sudden I had steam coming out the hood definitely coolant I couldn't tell where it was coming from so I waited till it cooled off topped of the coolant n ran it till it was at temp then drove it n no leaks anywhere y did it do that 2000 Honda accord se
Old May 16, 2016 | 06:19 PM
I'd probably stop by a parts store and get the radiator pressure tester loaner tool. Connect it to the radiator and pump up the system to around 16 psi. Does the system hold pressure at ~16 psi?
Do the same test on the radiator cap (it should hold pressure until the psi marking on the cap).
Old May 17, 2016 | 08:48 AM
rockhoundrob's Avatar
Next time there is steam, pop the hood and look. You should be able to see where it is coming from.
Last year I had steam coming out of the overflow tank because the coolant was hotter than it should be... turns out one of the cooling fans was not working. That was why I did not see a coolant leak on the concrete.
Old May 22, 2016 | 11:46 PM
Damonj's Avatar
I figured it out it was the heater hose under the distributor right at the block new hose n hose clamps it's all dry now
jagman1971
Jan 17, 2015 04:28 PM
tzoromski1
Oct 4, 2012 10:24 PM
Cubeman
Jul 23, 2012 12:40 PM
zZHellBlazerZz
Jun 15, 2011 10:12 AM
art vandelay
Aug 2, 2010 09:29 AM
