Coolant Question?
Old Nov 4, 2006 | 03:52 PM
dappa1's Avatar
Default RE: Coolant Question?
so only prestone and zerex 50/50 are good, what about peak brand?
Old Nov 4, 2006 | 05:41 PM
deserthonda's Avatar
any brand will do .....
Old Nov 4, 2006 | 06:21 PM
drummer1279's Avatar
yeah thats wa justmy personal recommendation, I use either prestone or zerex because peak isnt readily available in my area.
Old Dec 28, 2006 | 03:26 AM
You can get all those brands includeing Peak too at your Local AutoZone Parts store..
Old Dec 28, 2006 | 03:49 PM
ArcticHonda's Avatar
I just changed mine and i put some prestone rust and scale cleaner through the system before i flushed the coolant. I'm not sure if the stuff works but it wasn't very expensive so i tried it.
http://www.prestone.com/products/coo...Treatments.php
Old Dec 29, 2006 | 02:57 PM
91boz's Avatar
I am new to this forum (1 month) and I just replaced the Tbelt and water pump and need to refill with coolant. My other car a 95 Acura Legend is very sensitive to the type of coolant used. Factory silicate and borate free coolant only is recomended to be used in the Legend. If the Prestone is used in this car the results could be a blown head gasket or bad water pump. There is a lot of debate on the subject on the Acura-Legend.com site. I am pleased to see that these problems do not exist with the Accord and I can save about $16 or more buying the extended life Prestone. I assume that this is different from Dexcool which is red. These days one cannot determine the type of coolant by color alone. The Toyota factory coolant is an excellent coolant and is not the same as Dexcool.
jerrym
Sep 19, 2014 02:52 PM
LordLivingston
Oct 30, 2013 01:59 PM
socalfornow
Nov 24, 2010 09:47 PM
Johnene
Mar 31, 2009 10:51 AM
Dhorn33
Jan 12, 2007 04:53 PM
