Cooling Fans Issue
Old Mar 12, 2018 | 10:25 PM
You are jumping the wrong sensor. That is the engine coolant temperature sensor that only the engine computer uses to read the coolant temp.
The engine coolant temp switch should have a green and a black wire going to it. On my 95 4-cylinder accord, the plastic connector was green as well. It should be near the thermostat housing.
Old Mar 13, 2018 | 07:47 AM
TexomaAccord's Avatar
Originally Posted by PAhonda
Each fan should get power from separate relays. It is a design where one fan if a relay fails. If you have access to the original fan wires on the harness side, turn the key to the II position, then short the coolant temperature sensor A. Check if you have power and ground to those wires.
lol I guess I misunderstood lol that connector is right at the thermo housing -- okay will look for a green one
So number 11 ?
https://www.hondapartsnow.com/genuin...-v6,3063065,11
btw the fan hot and fan negative wires at the fan should be which color?
Old Mar 13, 2018 | 03:28 PM
Ok, I can report that when I jumper the proper switch, the fans do come on, but no power at the other plug (that was cut off from before)
Old Mar 13, 2018 | 05:42 PM
Pictures
Old Mar 13, 2018 | 06:23 PM
Hooked up my reader, got p0117 and p0118
Old Mar 13, 2018 | 08:45 PM
I would think blue and black based on the diagram you found. My 94 shop manual for the 4-cylinder says blu/yel and black. What are the wire colors that were cut?
The codes are for the coolant temp sensor. You likely set the codes when you had the sensor unplugged and were shorting the connector. Just clear the codes and see if they return.
Back to your testing. What happened when you tested the relay socket that turned on the fans, but switched the test light to the + battery post.
Old Mar 13, 2018 | 10:39 PM
  #17
The wires on the con fan (which are running both) are blu/yel and black. --- the ones on the rad fan (cut) are blu/black and black
and yes, the codes --- lol I had the plug still unplugged. will jumper, key on, test light to + Post and touch that relay plug..
Old Mar 14, 2018 | 11:14 AM
  #18
probe lights up
Old Mar 14, 2018 | 06:51 PM
  #19
Im wondering if I have a bad ect switch? its odd.. maybe I should video what happens? would that help?
Old Mar 14, 2018 | 07:56 PM
  #20
ok, further testing.. I hooked up my torque pro, watched the temp reading.. it got to 183, fans never came on. I turned the fan control dial to 1, water temp started dropping, fans came on... So Im guessing faulty ect?
