Cooling and Radiator Fans not coming on even with A/C switch to ON
Old Jun 20, 2011 | 11:03 PM
  #21
pab59y's Avatar
thanks, poorman212. i agree, this forum is better.
Okay. jumpered switch A and both fans worked. So, what does that mean?
Old Jun 20, 2011 | 11:52 PM
  #22
phatboyslim2012's Avatar
ok, you will need to buy a new radiator temp switch, napa autoparts was the only store that knew the part i was looking for, the two switches look the same attached to the car, but the connector on the switches themselves are color coded, make sure the color matches! the switch was $25, and required a large socket w/ a 1/2" wrench unfortunatly i cannot remember the size. very straight forward, take the old out and new in, if your car has a coolant bleeder, bleed the system to get air out. 10 minutes tops for whole job. when its done, start car and let idle 10-15 mins depending on air temp, mine took more time to kick in cause it was cool out im guessing, but the fans shoul kick on
Old Jun 20, 2011 | 11:56 PM
  #23
pab59y's Avatar
thanks. so, will this get both fans to work or just the rad fan? also, where is the coolant bleeder if the car has one and what does it look like?
Thanks again!
Old Jun 21, 2011 | 12:01 AM
  #24
my cars a bit newer so i am unsure of the location for yours, poorman can prob. tell you, but its just like the brake bleeders, 8-10mm bolt with a hose nipple and hole on top, its located about 2-4" behind the switch looking at it from the passenger tire on my car. loosen the bolt with car running, and tighten once a steady stream of coolant is coming out, then your done, according to poorman both fans should run, mine doesnt run because its shot and the bolt wont come off to replace fan
Old Jun 21, 2011 | 12:04 AM
  #25
pab59y's Avatar
thanks phatslimboy2012 ...
i was looking online at autozone and they have coolant temperature switch, is this the same? are there other names this it called?
Old Jun 21, 2011 | 12:10 AM
  #26
autozone has it online but when i went to the store they looked at me like i had two heads, insisting it was the temp sensor i needed, same with advance, pepboys, and carquest, if you go to autozone make sure you write down the part number and yes thats what you need
Old Jun 21, 2011 | 12:12 AM
  #27
pab59y's Avatar
okay. i found it online at napa auto parts. it is the coolant temperature switch -ATM 1435065 for 25.49, correct?
Old Jun 21, 2011 | 12:18 AM
  #28
its prob be what you need, the part numbers are prob different betwen our cars, but the reciept shows, fs244 - coolant fan switch - net 24.69, this is for the 97 accord 2.2L, ill check napa for you to make sure
Old Jun 21, 2011 | 12:22 AM
  #29
so it seems to be ATM 1435065, its a diff. part number cause mines a napa, and thats an altrom, has a flat brass end that screws in and a black connector
Old Jun 21, 2011 | 12:31 AM
  #30
pab59y's Avatar
thanks. i will order the ATM 1435065 from napa auto then.
