Cracked block experience?
Old May 4, 2010 | 07:55 PM
MacStrong's Avatar
Default Cracked block experience?
I blew a radiator hose and the mechanics said I have tranny fluid in the coolant.
they pressure tested the radiator and it's supposedly good
they said the only other option is a cracked block....
anyone with direct experience of this?
thanks fellas
Old May 4, 2010 | 08:55 PM
finch13's Avatar
Smells like BS.
Tranny fluid in the coolant? Correct me if I'm wrong guys, but I don't think ANY Accord has ever had an integrated tranny cooler in the radiator. That's the only way I can think of the fluid mixing.
Highly doubt it's a cracked block or head also.
Take it to a different (read: reputable) and get a second opinion.
Old May 4, 2010 | 09:21 PM
Can they explain how tranny fluid can get through a cracked block into the coolant? If it was a cracked block why isn't it engine-oil in there?
The radiator is the only place where tranny fluid gets together with coolant.
Old May 4, 2010 | 09:25 PM
Originally Posted by finch13
Correct me if I'm wrong guys, but I don't think ANY Accord has ever had an integrated tranny cooler in the radiator...
OK, you're wrong.
It's only on an auto-trans, but the tranny-fluid hoses go out to the bottom of the radiator. There's a metal tube inside the lower tank where the ATF goes across the width of the bottom tank. #11, 12, 13, 14 are the ATF hoses.
Old May 5, 2010 | 09:02 AM
MacStrong's Avatar
thanks guys---just talked to the wrench and he says it's engine oil NOT tranny oil
I would have sworn he said tran but it's engine oil
says they've checked all seals and gaskets and there is no other option--your thoughts?
Old May 5, 2010 | 12:41 PM
Then yes it can be a cracked block. It can also be a bad headgasket, but maybe he ruled that out by doing a leakdown test? I'm not sure how you would decide between a cracked block vs a cracked cylinder head?
Old May 5, 2010 | 05:51 PM
deserthonda's Avatar
i would be really shocked if it truly turns out to be a cracked block..
i would more likely suspect a head gasket or a warped or cracked head , way, way before a cracked block
how did they determine that it is a cracked block ??
if they insist that it is the block,, I would have a second opinion form a shop that specializes on Hondas or the dealer
Old May 6, 2010 | 07:12 AM
MacStrong's Avatar
they said they ran all the head and gasket tests they could
I also told them I was going to sell the car if it was the block so they don't have an incentive to screw me.
thanks fellas
rodethedragon
Jul 23, 2010 07:35 AM
gflemin3
Jun 19, 2010 01:02 PM
delsen66
Nov 14, 2008 11:46 AM
miami honda
Jul 11, 2007 05:32 PM
kjinpb
Aug 19, 2005 10:42 PM
