D4 Light; 94 Honda accord EX 4 door, 4 cylinder automatic
Old May 6, 2010 | 08:21 AM
rmasson's Avatar
Default D4 Light; 94 Honda accord EX 4 door, 4 cylinder automatic
Noob here with a transmission question. I have a 94 Honda accord EX 4 door with a 4 cylinder automatic. The D4 gear selector light will flash a sequence of numbers. They are 4-1-2-7-8. What do they signify? Here’s the lowdown:
The last week while leaving the gas station the transmission suddenly acted as if the clutch had gone out. The engine would rev but the car wouldn’t accelerate. The D4 indicator light was blinking and continued to blink even when I shifted to a different gear. I shut down the car and restarted and the problem went away. It has not happened again.
Meanwhile, previous to this incident and still continuing, the check engine light comes on intermittently while climbing hills on the highway. When looking for the check engine light fault code I noticed the shifter D4 indicator light was blinking as well. The D4 light flashed a definite pattern of a long flash followed by short flashes counting 4-1-2-7-8. Is this a fault code and if so what does it signify? As for the check engine light, it was flashing a 4-3 which the manual states is a fuel supply problem, guess I’ll start by replacing the fuel filter. Any comments/advice are greatly appreciated!
Thanks,
Ross
Chris Jameson
Feb 19, 2013 06:39 AM
Motman Idaho
Mar 22, 2012 10:20 PM
STINKA621
Mar 9, 2009 07:53 AM
PJ_STYLES_95AccordEx
Oct 24, 2007 09:58 PM
Ronnie101
Jun 21, 2007 09:44 PM
