Crankshaft sensors
Old Dec 30, 2007 | 09:28 PM
imjrk's Avatar
Default Crankshaft sensors
'96 Accord EX VTEC automatic: Swapping engines and have a quandry. Engine that came out of the car has two sensors behind the crankshaft pulley. Engine that I purchased to replace this bad engine has no way of bolting these sensors on. Will not installing these sensors cause problems? Are these a type of crankshaft positioning sensors? Engine will operate fine without them installed? Am I in a world of hurt? Thanks
Old Dec 30, 2007 | 10:15 PM
HondatechAV6's Avatar
Default RE: Crankshaft sensors
what is the engine you bought? (post the engine code)
Old Dec 30, 2007 | 10:38 PM
nafango2's Avatar
i believe they moved that sensor to the distributor... but dont quote me on it. (but that doesnt mean you can just bolt it up to the head)
Old Dec 31, 2007 | 08:30 AM
imjrk's Avatar
Old engine: F22BI, 3416157, and above the "USA POA-15", B5828281072P. Purchased engine: F22B, 3056221, and above the "USA PTO-10", 5A1116461I.
If the sensors are on the distributer on the purchased engine, A.) I did not recieve the distributer with the purchased engine, B.) Will the electrical harness directly attach? C.) If not, where do I find the proper wioring harness?
I am in a world of hurt, aren't I? Thanks
Old Dec 31, 2007 | 09:56 AM
academic's Avatar
I am having similar problem with 95 2litre [see earlier entry]. You need to check diagnostic codes.Bad news is that the sensor is part of the distributor so the whole unit has to be replaced. There's a nice way to start New Year !
Old Dec 31, 2007 | 07:45 PM
imjrk's Avatar
According to the person I purchased the engine from, I need to swap oil pumps because the mounting holes are on the oil pump. My inexperience working on Honda engines, I guess. Oil pumps are in the crankcase in American Iron.
Thanks
Old Dec 31, 2007 | 10:50 PM
yeah, it looks like you can swap the oil pump housings and reuse your current distributor.
the good thing about the honda pumps is...i've never seen one go bad! just my luck?
Old Jan 1, 2008 | 08:50 AM
imjrk's Avatar
The oil pump looks like it is an SOB to change, for the Honda repair newbie? Is there anything I need to know about the oil pump swap, any Gotchya's? Any good advice on finishing the engine swap? Pulled engine alone without auto tranny. Should be ready to put back in after today. Replaced all gaskets, inc. head gasket, belts, tensioners, water pump, etc. Any advice is greatly appreciated, especially from people who have done this before. Like I said previously, up until this engine swap, I have only worked on American Iron. Thanks
Old Jan 1, 2008 | 12:31 PM
I haven't done this, so I won't be much help.
Your old engine was F22B1 (not "I"). First digit 3in theserial # indicates it's the 3rd year for that engine.
Your 'new' engine is nota USA engine, since it's just F22B.
The details of those sensors changes from time to time, & also changes depending on the country of the engine. That's why it's often better to use all the sensors off your old engine, along with your original ECU.
Old Jan 1, 2008 | 12:37 PM
98dodgeneondohc
Jun 26, 2006 03:14 AM
moto310
Apr 30, 2006 03:16 PM
redlines
Oct 10, 2005 06:13 AM
enerlevel
Sep 5, 2005 02:26 AM
Rasher
May 17, 2005 01:19 AM
