CRAZY Tach in my 96EX V6
Old Jul 14, 2006 | 06:28 PM
daarkstaar
Default RE: CRAZY Tach in my 96EX V6
i've got the same problem with my '95 ex v6. the tach bounce doesn't start until after the engine warms up, but when driving, the engine misses periodically when the needle plummets. it occurs at idle also (needle bounce, not the missing). i changed out the icm (ignition control module), but no luck. i just read about another guy with the same problem, and he said that replacing the ignition coil will solve the problem. i've got one on order from rock-auto, and will post the results.
Old Jul 14, 2006 | 06:33 PM
daarkstaar
i forgot to mention, i tried a diagnostic on the obd at checker auto (they do it for free), but unfortunately it returned no error codes. also, i was told a computer will only pull codes if the check engine light is lit (i don't know how accurate that statements is, but it's what the checker guy said).
Old Jul 14, 2006 | 09:47 PM
Chiovnidca's Avatar
An internal problem in the ignition coil is the most likely cause of a jumping tach on a v6. It's a common problem.
Old Jul 14, 2006 | 11:05 PM
YeuEmMaiMai's Avatar
what he said
ORIGINAL: Chiovnidca
could also be bad ignition module as well or voltage is not at properl levels (13..8-14.7)
Old Jul 18, 2006 | 11:27 PM
daarkstaar
i just got the ignition coil today, and installed it. sure enough, the tach has stopped bouncing, and the engine has stopped missing.
hank97
Aug 31, 2014 10:30 PM
snicrep
Jan 11, 2013 08:07 AM
husrddy76
Jan 26, 2010 07:24 PM
96AccordEXV6
Mar 4, 2007 06:49 PM
Julian91
Jul 26, 2006 12:41 AM
