Cruise Control 1995 Accord LX
Old Sep 27, 2012 | 07:13 PM
gibbygano's Avatar
Default Cruise Control 1995 Accord LX
I have jumped around a few different threads here and on Honda Tech. Basically I have the issue that my lights will all come on when I hit the main cruise switch and the cruise set on the steering wheel. Soon as I let off the accelerator the car decelerates just as if I didn't have cruise on at all.
I have checked ALL of my fuses under the hood and under the steering column. I have also removed the cable linkage from the actuator and done a vacuum test by pressing in the bellows, removing the vacuum lines, and holding the ports closed with my fingers and the bellows has stayed depressed until I remove my fingers. The actuator appears to be in good working order.
I have also tried searching for vacuum leaks. I am not very experienced, but I used the carb cleaner as suggest and sprayed around the actuator vacuum lines and other vacuum lines with no drop in RPM's. I have also removed and plugged back in any molex connectors I can get my hands on, especially the ones near the actuator. I also unplugged the control module for the cruise control under the dash and made sure the plug was clear of debris and plugged it back in. I would check the break switch, but I'm pretty certain that the light on the instrument panel would go off if any of the switches were bad. It's not a question of disengaging, it's not setting in the first place.
Sorry for the long first post, but I have covered all of my bases I can think of and am looking for any suggestions.
Thank you.
Old Sep 27, 2012 | 09:23 PM
How did this work on HT?
My first question, auto or manual trans?
2nd question - do you have a volt meter?
Old Sep 28, 2012 | 04:27 PM
gibbygano's Avatar
Sorry for the delay. I thought I had it going yesterday, then today on the highway it didn't work again. Then I parked my car at the store and when I tried again on my way home it worked :/. Not sure what's going on.
Question 1:
It's a 4-speed automatic.
Question 2:
No, but I can easily get one.
On Honda Tech they had pretty much the same synopsis. The actuator must be bad, but I have confirmed the bellows are in perfect working order and can hold a vacuum very well.
Last edited by gibbygano; Sep 28, 2012 at 05:22 PM. Reason: Didn't answer all questions.
Old Sep 29, 2012 | 09:18 AM
What did you do to "get it going"?
Check for stored codes just for giggles.
The vac tank for the act is under it, I know you checked for leaks but it is a bit hard to get under there.
Strider
Feb 6, 2013 05:56 PM
Flyboy86
Oct 22, 2010 09:45 PM
alfredo123
Jul 24, 2006 01:09 AM
toka
Apr 1, 2006 06:12 AM
rabbit
May 3, 2005 01:28 AM
