Cruise control not working?
Old Nov 10, 2009 | 07:22 PM
jmtdaddy's Avatar
Default Cruise control not working?
I fixed my speedo problem is fixed turned out to be the cluster the vss has been replaced as well when i hit the set cruise button the cruise control light comes on but does not set the speed what could be the problem??
i appreciate you guys
thanks
brandon
Old Nov 11, 2009 | 06:42 AM
I'm too lazy to look up your other thread, so I have no idea what kind of car you're talking about.
Brake switch stuck closed? Are you brake lights on full-time?
Clutch switch stuck? Do you have a manual tranny?
Bad cable-reel in the steering wheel hub? The "set" button doesn't connect properly to the cruise module?
Old Nov 11, 2009 | 09:13 AM
00AccordLX5spd's Avatar
Registered User
I looked at his old thread: 94 lx coupe 5-speed - you might want to put this in your signature bud. Some members will not even respond unless you have this info in your signature.
Are you 100% sure your foot is completely off the clutch when you try to set the cruise? My foot cannot even be touching the clutch in my car for the cruise to work. Sometimes I'll try to set it and be like "What the..." then realize my foot is barely touching the clutch.
Old Nov 11, 2009 | 10:26 AM
It's a BAD HABIT to rest your foot on the clutch pedal, Jon...
I kinda liked how sensitive the Honda was for that. On the Saabaru, you have to press the clutch down a bit before it cancels the cruise.
Old Nov 11, 2009 | 03:25 PM
jmtdaddy's Avatar
yes i have a 94 lx coupe 5-speed and i have my foot completely off the clutch and it still does not work and how would i fix or check rather the the reel in the steering wheel hub? if that could be the problem??
Old Nov 11, 2009 | 04:29 PM
I have never had to troubleshoot the cruise control on my car. My best advice is to download a 94 shop manual from the spoon site I posted on the Online Manuals thread in the DIY section.
Rob_KCMO
Apr 18, 2010 12:05 AM
mtrapuzz
Mar 2, 2010 05:49 PM
russler01
Feb 23, 2008 12:19 PM
aatc20
Sep 25, 2006 04:28 PM
wskipper
Nov 19, 2005 03:49 PM
