Cruise Control Problem
Old Jun 10, 2016 | 09:39 PM
  #21
Waynard's Avatar
I too am having cruise control problems on my 2000 Honda Accord EX. I was looking at the throttle body and saw that the cruise cable was laying limp in the groove. I rotated the cam and see that the hole for the cable boss is broke. The throttle body is the problem but I refuse to buy a new one. I will go to a Pull a Part to find a used one or will manufacture a fix for the one I have. I will let you know how that works out. A throttle body is able to cause cruise problems. Easy to find but not easy to fix if you dont go for the new OEM parts.
Old Jun 11, 2016 | 05:09 AM
  #22
Good luck with the fix.
Let us know how it goes and which way worked out for you.
Old Jun 11, 2016 | 11:04 AM
  #23
obamathelegend's Avatar
oke thanks information welcome the accord forums
Old Jun 11, 2016 | 11:36 AM
  #24
Please post something close to a response or help WITHOUT that attachment. Not sure if you are a spammer or not. I see you are in CA so I didn't ban you right away.
Old Jun 24, 2016 | 12:58 PM
  #25
barra340's Avatar
check the vacuum. If the actuator is not getting vacuum it will not engage.
Old Oct 7, 2016 | 05:29 PM
  #26
footprintsinconc's Avatar
i did pull on the cables earlier and they seemed taught. i could not find any vacuum tubes to the actuator...does anyone have any pics?
well i think i found the issue with my cruise control...will check for that cable this weekend.
Old Oct 9, 2016 | 11:34 AM
  #27
found the cable end for cruise control was hanging out there...will have to remove the TB and try to fix it without replacing the TB. poor design on Honda's part, unbelievable.
Old Oct 10, 2016 | 05:10 AM
  #28
Sounds strange but I'm glad you found the issue.....now to try to figure out how to fix it
Old Oct 10, 2016 | 11:11 AM
  #29
its the same issue that everyone has had where the plastic thing that holds the cable is broken.
some people have epoxied the end of the cable ball into the plastic thing...this will restrict the cable end from turning when its pulled on, isn't that going to restrict or break something else?
Old Oct 23, 2016 | 01:17 PM
  #30
I fixed the cruise control! here is a pics and video of how to do it...thanks to cowsarered suggest fix!
here is the video link
Attached Thumbnails Cruise Control Problem-1-gweohnpukd2ekx9wrkxxi1pml4aolsjgud4m8ajadop8abpnmu1ymmmqmiqn1du4zu99of6gdolg07rk0lcbadvtc0yul5.jpg   Cruise Control Problem-1-gweohnpukd2ekx9wrkxxi1pml4aolsjgud4m8ajadop8abpnmu1ymmmqmiqn1du4zu99of6gdolg07rk0lcbadvtc0yul5.jpg
