cruise control prolems
Old Nov 3, 2012 | 04:26 PM
bago boi's Avatar
Default cruise control prolems
i recently bought a 2004 honda accord EX, 4 cylinders vtec, however when i try using the cruise control the main swtch lights up but when i depressd the set botton it does not stay engaged. Can someone help me with this? Am i doing something wrong or is there something wrong with it?
Old Nov 3, 2012 | 08:12 PM
Check your brake lights - are they on all the time? If the brake switch is not right, it just immediately cancels the cruise.
Old Nov 4, 2012 | 07:08 AM
Even if the brake lights are off, the switch can still be bad or out of adjustment.
Do you have a voltmeter and a bit of time?
Old Nov 4, 2012 | 10:25 AM
bago boi's Avatar
Thanks guys... The brake works fine so ill try readjusting the switch and let you know the result of it.
Old Nov 4, 2012 | 10:36 AM
You can test it....also know there are other things that can be the issue (clock spring, fuse, ect), just the brake switch is the most common.
Old Jun 3, 2013 | 05:12 PM
n0bld's Avatar
Default problem only with the switch
I need help. I have a 2004 honda accord DX with cruise control. The switch brook as all things do, but I took it to the dealer and of course my car doesnt come with cruise so they say it must be after market. Well the column cover does not appear to be aftermarket and has honda stamped on it. The switch is pressed into it and I cant find any numbers on the switch. How do I figure out a switch. I just need working cruse again.
Switch is on a metal stem and looks like all standard cruise control switches but just by itself
new2honda
Feb 5, 2007 01:34 PM
wskipper
Nov 19, 2005 03:49 PM
SeminoleB
Nov 9, 2005 01:52 AM
rabbit
May 3, 2005 01:28 AM
austinbc1
May 2, 2005 08:16 PM
