CV Axle Balance Weight Question
Howdy folks,
I got a 2004 honda accord that developed a bad CV axle (possibly)
And I've ordered brand new cv axles from autozone, and they came without the balance weight (you can see in above video, it's the weight that's clamped in the middle of the rotating arm) that's installed on my original cv axles..
Are those balance weight required? How come my new axle doesn't come with it..
here is pic of the new cv axles I got along with tools to tackle the job myself
Thanks for your help
I have never seen a CV joint wobble like that and if the wheel like in the video is also wobbling I would be thinking wheel bearings or something else like the hub. On the damper it is very common not to have them on reman axles and I never heard of that creating a problem even at the Honda dealer I worked at.
Hmm, I was trying to pull the CV axle back and forth and it's got quite some play in it... Didn't check the bearings, I'll do it when I have the chance, thanks.
Something is wrong to cause that much wobble in the wheel and hub assy. Massive out-of-balance would be necessary to cause that much vibration at engine idle. Hit any big pot holes to bend the wheel rim?
I had problems on my 94ex w/ AZ axles, rebuilds not new, which was finally resolved when Raxle brand cv axles were installed (w/ vibration dampners!).
I would keep the driver's side axle.
My steering wheel vibrates at ALL speed ranges, and particularly worst at 20-40mph. The vibration pattern is of back and forth rocking to the left and right of center, and the car would drive straight if i don't touch the steering wheel.
On reverse gear it's a different story, the car would immediately tilt to one side as soon as it's in R gear...
Speaking of tire thread... almost all the left/right side thread is gone on both driver and passenger side of the front wheels...
My wife hit the curbs with my car more than once in the last 2 years... But I just did wheel balances and I see that all the weights are still on the rims, maybe I need to carefully inspect the joints as well as the rim/bearings and switch out the rear tires to the front and see what happens, since both of my rear tires are in like new condition with no thread damage.Gas mileage on highway has been good as well, hitting 32-35mpg, locally, the mpg has been 18mpg
Thread wear Front Passenger Side (one that's having the wobbly CV Axle, it's also worth mentioning that the inside of the front tires have similar wear with no threads left..)
Thread wear Rear Passenger Side
Front Driver Side
Rear Driver Side
After thinking about your car more and watching the video again. I am not sure if the axles have an issue as the wheel are turned and that up and down of the axle may be normal to CV joints. I not sure. Both front tires do have an issue which may be a bent rim, hub or just the tires. My first guess would be belt shifts in the tires. Years ago on here someone had the brakes done at a repair shop and they changed the Honda Recessed rotor bolt with a standard bolt and it kept the wheel from being flush to the rotor and caused a major vibration. When did the issue start?
