CV Axle Balance Weight Question
Old Jan 9, 2014 | 10:24 PM
accord_li's Avatar
Originally Posted by kris_loehr
After thinking about your car more and watching the video again. I am not sure if the axles have an issue as the wheel are turned and that up and down of the axle may be normal to CV joints. I not sure. Both front tires do have an issue which may be a bent rim, hub or just the tires. My first guess would be belt shifts in the tires. Years ago on here someone had the brakes done at a repair shop and they changed the Honda Recessed rotor bolt with a standard bolt and it kept the wheel from being flush to the rotor and caused a major vibration. When did the issue start?
Hmm, good you asked, about 4 month ago I did a brake rotor and brake pad change myself with autozone's "duralast gold" pads and rotor, because a year ago I've done the most stupid thing in my life and went to "Just Brakes" for a $100 "complete brake job", and the brake haven't been performing normal till I did the job myself.
Everything has been normal till two weeks ago that I noticed a significant vibration across all speed ranges.
I didn't have a torque wrench when I changed the rotor and pads but now I got a proper one along with impact wrench so I can take everything apart and do a better inspection this weekend and then give a update of my findings.
Old Jan 9, 2014 | 10:55 PM
kris_loehr's Avatar
Unless someone replaced the bolts that hold the rotor to the hub with bolts that aren't flush with the rotor you should be fine. If this happened you would know immediately someone was wrong. I would jack up the car(and jack stands) and with grab the tire top and bottom and see if there is any free play.
Old Jan 10, 2014 | 11:59 AM
accord_li's Avatar
Okay, whew, problem solved thanks to all you guys help..
I switched the front/rear tires and the vibration problem was completely gone on the steering wheel, so it must be the tires/rim combination that's causing the vibration at all speed ranges...
Now I gotta return the axles and get some new tires and maybe get rims checked out
Old Jan 10, 2014 | 01:38 PM
kris_loehr's Avatar
Good Job
Old Dec 12, 2024 | 03:52 PM
HomdaEnthusieyDiYiEr8690's Avatar
Default “Should be OK”
It's called a dynamic damper. Most aftermarket axles will not come with it. You should be okay without it.
well this is probably already answered. But I couldn’t scroll down. But what if you still get a bad wobble after several different of the same aftermarket” brands (Orilley’s import direct and now i dew like my cheap rock auto ones are doing the same thing:: 04 accord coupe auto 2.4
Old Dec 12, 2024 | 07:02 PM
kris_loehr's Avatar
Then your issue may be something other than a half shaft.
SKHEMR
Feb 3, 2020 11:27 PM
Reggi's-accord
Jun 6, 2012 07:17 PM
Deejayphilo
Mar 30, 2012 04:15 AM
nixalot
Jan 25, 2007 02:02 PM
kidwidstyle
Aug 2, 2006 04:59 AM
