Cylinder Position sensor
Old Jul 23, 2011 | 04:06 PM
SoftDad's Avatar
Question Baffled - CYP checks out OK.
2000 Accord, 4cyl. Engine check light on. Flash code 9 (CYP fault). CYP resistance 985 Ohms (within spec). No continuity to ground. Checked (visually & by feel) the connections at the PCM. Cleared code and fault signal returns.
Now what? dh says to "chk at the ecu connector". Engine Control Unit. I guess PCM (Powertrain Control Module). Am I missing something?
Is anybody still following this old thread? Any leads greatly appreciated.
Old Jul 23, 2011 | 06:27 PM
You disconnect the correct connector at the ECU. This will require removing retaining nuts on ECU module to access the connector. Check resistance of CYP sensor from that connector.
If the reistance at that point is same as from the distributor, then ECU has a circuit board fault. A shop manual is essential for finding correct connector and wire colors.
I had exactly the same problem w/ my 94EX. A replacement used ECU found via car-part.com fixed the problem.
pondrun
Nov 8, 2021 09:40 AM
keefer
Jun 16, 2008 08:29 AM
cws42680
Nov 26, 2007 10:43 PM
iamiles
Oct 18, 2007 08:54 AM
jazmyneaccord81
May 20, 2007 10:52 PM
