crank position sensor
Old Jun 11, 2008 | 04:56 PM
keefer
Default crank position sensor
I have a 1997 accord se 2.2 automatic. I just replaced timing belts water pump distributer cap and rotor. The car starts and idles fine. Under a load it misses and bogs down. The check engine light is on and show a problem with the crank position sensor. I just checked the wires to it and they are fine. Could I have damaged it when replacing the timing belts? Will I have to remove the timing belts to replace it?
Old Jun 11, 2008 | 05:11 PM
Default RE: crank position sensor
Might be able to clean up the toothed wheel that triggers it,IF the problem is magnetic gunk.
Old Jun 14, 2008 | 09:21 PM
keefer
Is it located in the distributer? I looked online and the part they show looks like what is behind the timing pully.
Old Jun 16, 2008 | 08:29 AM
Yes, behind the timing pulley. PITA to dismantle & reach that all over again. Remove crank pulley but maybe dont need to remove timing belts.
pondrun
Nov 8, 2021 09:40 AM
Pacman311
Sep 28, 2013 06:26 AM
Tyler Joyce
Sep 24, 2012 08:52 PM
argarcia86
Feb 23, 2012 06:49 AM
dineromike1
May 26, 2010 10:57 AM
