d4 codes 1 8 13 14
Old May 9, 2012 | 10:02 AM
iLOVEmy94's Avatar
Default d4 codes 1 8 13 14
I got my transmission rebuilt a year ago and it has rough acceleration, so I really haven't driven it much throughout the year. Now, that I've started driving it more often I see my d4 light is still blinking like before. So, I checked the d4 codes and I get 1 8 13 and 14. What are these codes? Whatever these problems are should the transmission place have fixed these already?
Old May 9, 2012 | 10:10 AM
hondadude's Avatar
With that many codes I'd suspect an electrical problem;
https://www.hondaaccordforum.com/for...es-obd1-32718/
You might consider a trip to the trnsmission rebuilder, and ask if they will make the job right for you.
Old May 9, 2012 | 11:41 AM
Suggest resetting the TCU (pull Backup 7.5A fuse for 20 secs) and checking whether same codes return.
Old May 12, 2012 | 10:13 PM
iLOVEmy94's Avatar
Default Update
After having the TCU reset, I am now only getting codes 1 and 8. What are these codes and what do you think I should do from here?
Old May 13, 2012 | 06:30 AM
Code 1 is LockUp Control Solenoid circuit electrical fault; solenoid, connector, wiring, or TCU circuit fault.
Code 8 is Shift Control Solenoid circuit electrical fault; solenoid, connector, wiring, or TCU circuit fault.
This must be a 90-97 (specify in your signature line). Suggest you download a manual to find the solenoids and perform electrical circuit checks to locate the faults. The solenoids may seem obvious but w/ two faults at once, I'm suspicious of wiring or TCU.
Old May 13, 2012 | 08:23 AM
Be sure to inspect the "connector" for the solenoids, I've seen a dirty/poor connection give codes like this before.
Old May 17, 2012 | 01:45 PM
iLOVEmy94's Avatar
Default Update 2
Okay, so now they've replaced the solenoids with used ones and if that doesn't work then we're replacing the TCU; which I suspect to be the culprit anyway. But, hopefully not so I won't have to put anymore money into this car right now. Trying to go on vacation in two weeks...
Old Jun 26, 2012 | 02:23 PM
iLOVEmy94's Avatar
Talking Update # 2!
So, the transmission place only gave me codes that I already knew. I took my car to my mechanic and put in a new main relay, that was 2 days ago and I haven't had any problems at all. The d4 light doesn't flash and the car cranks up fine in hot weather now!! I'm SURPRISED everytime I crank up the car with no problem. I hope this thread helps someone with similar problems as mine..if anything changes I will definitely give another UPDATE!!
Old Jan 25, 2018 | 12:27 PM
Sebastian1's Avatar
Default I need help I have the same problem
Did you end up replacing the tcu I’m having the similar problem I have no spark in ignition and just replaced the ignition coil and starter relay
saad180
Jan 3, 2007 10:45 PM
deserthonda
Jan 18, 2006 11:59 AM
Lance Link
Jan 17, 2006 04:17 PM
davwha
May 3, 2005 01:19 AM
B0BC0X
Dec 7, 2004 03:04 PM
